Insomnimrod
- Jul 6, 2009
Here is a system I am planning on building. Will use mainly for gaming (Crysis, GTA IV, Call of Duty 4, etc.) I would appreciate any input. I have done lots of research, but never built rig before. This build comes in at a hair under $1400 at newegg, I have budget of $1600. I was thinking the case could be better, but don't really know which ones are considered high quality.
Rosewill R5730-P BK 120mm Fan Pre-Installed on the Top and 80mm Slim Fan Cooling HDD,ATX Mid Tower Computer Case
MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard
XFX Radeon HD 4890 1GB 256-bit DDR5 PCI Express 2.0 x16 HDCP Ready
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor
Crucial 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Triple Channel Kit Desktop Memory
HITACHI Deskstar P7K500 HDP725050GLA360 (0A35415) 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
Acer X233Hbd Black 23" 5ms Widescreen LCD Monitor
LG 22X DVD±R DVD Burner Black IDE Model GH22LP20 LightScribe Support
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders
