First Build! Need Last Minute Advice
civictyper16
Hey guys any last minute advices on my rig still a little hesitant about the ram don't know what to go with.Computer is gonna be used heavy on gaming and some 3d modeling and movies.I will want to overclock this pc a little my budget $1,100.I already own a power supply and case!
ASUS P5N-E SLI=$139.99
http://www.newegg.com/Product/Product.asp?item=N82E16813131142
Intel Core 2 Duo E4300=$177.99
http://www.newegg.com/Product/Product.asp?Item=N82E16819115013
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800=$209.99
http://www.newegg.com/Product/Product.asp?item=N82E16820231087
EVGA 640-P2-N821-AR GeForce 8800GTS=$389.99
http://www.newegg.com/Product/Product.asp?item=N82E16814130071
Western Digital Caviar SE WD2500JS 250GB=$69.99
http://www.newegg.com/Product/Product.asp?item=N82E16822144417
ARCTIC COOLING Freezer 7=$49.99
http://www.newegg.com/Product/Product.asp?item=N82E16835186134
Price=$1,037.94
Thats some nice ram. I'd switch the HDD to the Seagate 7200.10 model instead. What PSU do you plan on using?
terrible choice on ram. I would not buy that
Why is it a terrible choice? Its a nice price for low latency. I got a couple kits (2) for the two builds I was working on when the price on these were $200 in december last year. They booted on the first try, but I had to adjust the timings manually. I usually get the higher latency g.skills (2GBNQ), and those work great, too.
Looking good!
All I can say is that if I were you, I would bump down the video card to a 7950GT (like this one), then use the spare cash to get a faster C2D.
or at least spend $10 more for the C2D E6300 model, it's a tad faster and doesn't have the compatibility issues I've read that the E4300 is having with some motherboards.
Oh and I have G.Skill RAM, very good in my opinion.
680i SLi bud, it's where it's at. I'd wait for the DFI version tho.... The ATI offering looks pretty slick too tho...
I was thinking about getting the e4300 because the 9x multiplier I'm a little confused right now i don't know what to do.
ASUS P5N-E SLI nVIDIA nFORCE 650 SLI CHIPSET
CORE 2 DUO E6300 1.86G (1066Mhz)
Bundled at MWave for $312.92
Tempting....?
$434.98 for E6600 w/ the 650i
$297.38 for the E4300 w/ the 650i
