Firewire HD problem
jfuller82
I'm having a problem with a firewire hard drive of mine. Whenever I try to access it, it wants to format the drive. When I say I don't want to it says the drive is unaccessable. Just a little history on what I think brought this on. A storm came through about 2 days ago and we had a power surge where the power went out for a second or two. The computer shut down and reset along with my firewire hard drives. Ever since then i've been unable to access the drive. I have 2 of these drives. The drive that is workin fine has had this problem before and i've been able to fix it by just turning the computer off and turning it back on but this time doing that isn't getting the other drive to work properly. I've also tried unplugging the drives and it had no effect when I plugged them back in. Both of my hard drives are Maxtor drives. One is an actual maxtor hard drive in a maxtor case while the other is a maxtor hard drive in another brand's case. I'm running Windows 2000 with all the latest updates. Any ideas?
well power loss or instability can easily cause corruption
the partition table could easily be fubar
personally Id simplify the issue by eliminating the firewire interface for now
see if that alone does anything
then Id recommend DIY Data Recovery's Disk Patch to rebuild the partition table
examine the partition ID ect.
an alternate possibility is to simply run a recovery application since it seem you have access, of course you need the space to rescue to.
For recovery Id recommend File Scavenger, seems to have a higher recovery rate than most aps out there
both of those run $40
