I'm going to guess that you just updated to Firefox 3.6 and you're really happy with how fast it is. However, if you're like me, you're probably really mad at the fact that personas only work on the default theme in FF 3.6. I've found a way to put personas on your favorite FF theme (not the default) while still being able to use FF 3.6.
1. Download and install Version 1.4 of the Personas Add-on
2. Before you restart, change the FF theme to your favorite one.
3. Once you restarted with your favorite theme, you should be able to mouse over the personas and they should appear on your favorite theme.
4. When you find a persona you like and click "wear it", the Persona add-on and FF 3.6's built-in persona support will conflict. It will try to install the persona like it normally does by putting it in the themes section under add-ons and it will ask you to restart your browser. Ignore this buy selecting your current theme by clicking "Use theme". If you did this properly, you shouldn't need to restart Firefox.
5. At first the persona won't show up, but once you close the add-ons Window, it should show.
6.Congratulations! You're now using your favorite theme and a persona at the same time, just like you used to be able to.
Until Mozilla realizes that taking out support for putting personas on all themes there will always be a conflict with Firefox 3.6 and the Persona 1.4 add-on so you will have to repeat this every time you change your persona. I advice against updating the add-on until they've put support back in for other themes.
Keep in mind that the current version of the Personas add-on works the same as FF 3.6's support, meaning you can only have a persona with the default theme. Just make sure you stay on Personas 1.4 (1.5.1 is the current version) and you should be fine until Mozilla resolves this.
I hope this helps any one who's just as frustrated as me. Post any questions you have. I come on Hardforum a lot so you're question should be answered pretty quickly
Update (1/23 @ 11:08PM): This applies after you have the Personas add-on installed and decide to change your theme. After you install the theme of your choice (or just want to change the theme) make sure you disable the Personas add-on before you restart to switch the theme. After you've restarted FF, go back to the add-ons and re-enable the Personas add-on. After you restarted after re-enabling the Personas add-on you should see the Persona that was previously on top of the theme you were using earlier. If you decide to change your persona again on your current theme, repeat steps 3-6 in the original post.
