well, i finally got all my parts in.. and im just slowly taking everything off my motherboard so i can start putting the blocks on..
well, i have an asus a8n-sli premium mobo and took off the heatsink for the chipset.. under the heatsink, asus seams to use this cheapo conductor tape thingy instead of the spread.. well, im having trouble removing all of the excess.. anyone have any tips?
the chipset is kind of weird because under the heatsink, the chipset is covered by a small thermal-type tape with a square opening for the chipset.. it's not like all the chipsets i've seen.. so how will i spread arctic silver 5 on there? should i just do it as if it were a regular chip like the cpu?
for the cpu, there is a black bracket around the cpu as a mounting bracket for the fan, if i take off those two screws holding the black bracket, should i take off the bracket to install the block? or should i leave it on? i have a swiftech storm block..
on the other side of the heatsink for the chipset, there is the fins, when i took off the fins, there were maybe 10 little chip looking things that it was attached to with the nasty thermal tape thingy.. i was wondering if it would be ok to just leave it as it is without the heatsink, or if i should cut off the fins and attach it back onto those little suckers.. i would really like to keep the stock heatsink so if i ever want to go back and get rid of my WC, then i could always have the stock stuff to fall back on..
sorry for so many questions, but id like to do things right the first time so i wont have to mess with it again.. thanks!
