Synthetickiller
- Apr 5, 2009
Parts list (typical stuff):
Motherboard: Gigabyte GA-H55N-USB3 LGA 1156 (putting copper sinks on the PWMs and mosfets)
CPU: Intel i3 530 (plan on OCing the heck out of this chip)
Ram: G.Skill Eco Series 4GB 2x2gb DDR3 1600 (7-8-7-24-2N)
Video: 8800gts g92 512mb (will either upgrade to a dx11 5770 or similiar or my gtx260 from my desktop rig)
Case: SG05/06 (can anyone justify the $30 extra cost of the 06?)
Intake Fan: Scythe GT 1850rpm
HDDs: own two 160gb 5400 rpm laptop drives (will upgrade later)
ODD: may buy in the future, if I need it.
Here's my problem:
1. What type of cooling for CPU & H55 chipset?
GeminII seems ideal since I want and need active cooling and the 120mm fan fits under the PSU, but the Corsair H50 seems to be a quick fix and should provide good temps. I do not want a Geminii dual 120mm since I need active cooling and retain all slots for hdds (I'll be dropping three 2.5" drives into this rig).
2. As well, do you guys feel the H55 needs active cooling (like Extreme Spirit II) besides the 120mm GT blowing cool air in from the front?
3. One other easy question, will the 300w PSU be enough for this set up (with 8800gts card)? I'll get the 450w if by some miracle it's bundled in the US, if not, I may buy it later as an upgrade for higher end video cards.
Here's my problem:
