Feedback on prebuilt system
Fooshnik
Normally I wouldn't believe in buying anything like this, but pricing out putting together a custom i3 system I'm running about $480 including windowz. Any thoughts? I'd have to add a bluray that's about it.
http://www.frys.com/product/7341714?site=sa:adpages
Specs here.
Lenovo H520s (57311128)
General Spec
Brand lenovo
Model H520s (57311128)
Type Student/Home office
Usage Consumer
Processor Intel Core i3-2130 3.4GHz
Processor Main Features 64 bit Dual Core Processor
Cache Per Processor 3MB L3 Cache
Memory 4GB DDR3 1333
Hard Drive 1TB SATA II 7200RPM
Optical Drive 1 DVD+/-RW
Graphics Intel HD Graphics 2000
Ethernet Gigabit Ethernet
Power Supply 180W
Operating System Windows 8
Motherboard Chipset Intel H61
CPU CPU Type Intel Core i3
CPU Speed 2130(3.40GHz)
L3 Cache Per CPU 3MB
CPU Socket Type LGA 1155
CPU Main Features 64 bit Dual Core Processor
Graphics GPU/VPU Type Intel HD Graphics 2000
Graphics Interface Integrated video
Memory Memory Capacity 4GB DDR3
Memory Speed DDR3 1333
Memory Slot (Total) 2
Maximum Memory Supported 8GB
Hard Drive HDD Capacity 1TB
HDD Interface SATA II
HDD RPM 7200rpm
Optical Drive Optical Drive Type DVD±RW
Communications LAN Speed 10/100/1000Mbps
WLAN 802.11b/g/n Wireless LAN
Front Panel Ports
Front USB 2 x USB 2.0
Front Audio Ports 2
Card Reader 7 in 1 (MS, MS Pro, SD, SDHC, SDXC, MMC, MMC Plus)
Back Panel Ports
Video Ports 1 VGA, 1 HDMI
Rear USB 4 x USB 2.0
RJ45 1 port
Rear Audio Ports
3 ports
Expansion
PC Card Slot
(1/1) PCI-E x16
(1/3) PCI-E x1
Speaker Speaker Features 15.75" x 11.54" x 3.94"
Physical Spec Dimensions 19.5 lbs.
It's kind of a turd, but it seems faster than what some people on this forum are using. Any dealbreakers here?
it kinda depends on what you are planning to do on this computer
Media playback. Perhaps some light gaming with older games, but that's not critical.
The Sandy Bridge i3's are surprisingly snappy chips. I run one in my lan rig and I notice no difference in light gaming or daily use than my i5 2500k. If you're not encoding or doing insane amounts of gaming the i3 is perfect.
This build seems like a great deal... Normally I run no less than 8gb of ram since it's so cheap these days, but that's something you can always add later on.
Looks sleek as well, I'd pull the trigger.
These are Canadian pricing so should be close
Case/PSU: 110ish
CPU: 120
RAM: 20
MB: 50
HD: 80
ODD: 20
= $400
Wireless Card: 15
Card Reader: 10
Windows 8:$100
Good deal overall with the wireless, card reader and windows 8.
Personally I would still build my own but go with a Trinity build. Your not doing anything too cpu intensive and the bump in gpu power is always nice for light gaming.
Just a bump for this, until 1/17 it's now $368. It's a nice system, if you add a 6570 you can use it for gaming. Perhaps a 7750 but not positive with that PSU.
