Infaustium
- Apr 16, 2008
Alright, I'm still a little unsure as to whether or not the temp sensors in the CPU housing of this ASUS Rampage Formula board are off or not.
Just bear with me, as I'm going to try to explain this as in-depth as I can, so there's no misunderstandings, thanks!
If anyone else is able to use multiple progs to monitor their temps with this board, that might tell me something.
After flashing BIOS, it's now reading temps normally, but the only third-party prog that will read my temps (showing same temps as my BIOS) is the latest full version of Everest.
RightMark will not show temps or info on more than one core, but does show activity taking place on both cores.
RealTemp is reporting no movement on sensors, indicating a problem with the sensors.
However, Everest (which has supposedly been very much updated with the latest release) shows all temps.
Is it actually the other progs not updated enough yet to read temps off this board?
Is Everest just "mimicking" the temps in my BIOS, and I've no idea whether or not they're actually accurate?
When I say "mimic", I mean that - are the temps reported by this BIOS on this board off, such as Intel's boards (always read 10C higher than reality) so Everest is not really helping me to see my actual temps?
It shows me idling at 34C, with the E8600 45nm, which is a little higher than the E6700, but seems about right. There's hardly any movement at all, only when gaming, and then only slight, but then again - this is a solid, high-end CPU that takes a lot to tax, as well as having a phenomenal cooler (Xigmatek S128) with a 120mm fan and AS5.
So perhaps it's just staying cool and not moving in temp (unless gaming) because it's not really being taxed, and being excellently cooled...?
I do need as much detailed feedback and ideas as possible from the ideas/perspectives I'm mentioning here, because I don't want to be missing anything and take the chance of any future damage or shortening of the longevity of this board/set-up/hardware.
Otherwise, I'm running perfectly, and though I expected some definite increase, this CPU and set-up is more than I expected. I was running an Intel D975XBX2, GTX 280, E6700 and 2GB Corsair Dominator (single channel) - now running the ASUS Rampage Formula, GTX 280 with the E8600 and 2GB Corsair XMS2 DDR 880 in dual channel, and there's a huge performance difference.
Wouldn't have thunk it, but... there it is, and I have to make sure that everything is "kosher" with the CPU temp issue.
I appreciate any time anyone could take to let me know if I'm alright here and it's just progs not supporting monitoring except Everest (and if it's, and the BIOS, temps are accurate), or if there's a potential sensor issue that I should be concerned about.
Thanks much!
Thanks much!
