It amazes me how many people in this thread totally miss the point of the article. Huddy compares a modern PC GPU and a very old console GPU and shows how the vastly inferior console GPU can OUTPERFORMED the vastly superior PC GPU because the PC is forced to choke on the DX API and the code for the console GPU is written directly to the hardware.
Everyone here bitches and moans how all the new FPS games look alike, no innovation, never touching the true potential of the PC hardware. THIS IS WHY!
Everyone was pitching a fit on here a couple weeks ago how the long awaited Crysis 2 is just another console port and does NOT deliver on the graphic potential of the Crytek 2 engine. THIS IS WHY!!!
WAKE UP PEOPLE> Your pragmatism has blinded you to what the possibilities are. Instead you chose the middle road because you bruise easily.
no.
A console got one function, no background services, no windows services, no antivirus. Its locked to 35fps. Runs at 720p. A three core cpu running at 3.2ghz and a gpu connected via a fsb. Now imagine you got lets say a triple core cpu, clocked to 3.2ghz and only need to generate 35fps at 720p and your running on a OS less demanding than Linux. Doesn't matter how junk the gpu is. The cpu and the gpu can perform that task at a low resolution. Both of them are working at full paste and influence the performance. Now when they start stepping up the resolution for consoles then that gpu for it got to change coz the cpu can't help it out as much.
That's why ports are so cpu intensive as well. The Xbox games are cpu intensive it needs to be to help that junk gpu out.
