Fan Templates [USEFUL]
wiretap
I was just thinking it would be easier to download a fan template pre-made instead of trying to struggle with making your own to cut holes in your case when modding. So.. that being said, I did a nice google search and found something useful. :)
http://www.moddin.net/downloads.asp
They have:
40mm Fan Template
50mm Fan Template
60mm Fan Template
70mm Fan Template
80mm Fan Template
92mm Fan Template
120mm Fan Template
5.25'' Bay Template
Black Ice Pro II and Black Ice Extreme II Template
Some of them say 'BETA' and are possibly untested, so hopefully someone can give us some input on how they work. Holding the "BETA" ones up to my 80mm and 120mm fans, they look to fit perfect.
edit: Open them in MSPaint for the best printing results. The windowsXP photo printing utility messes up the sizes.
Cool find! I always hated trying to use a fan as a template to make a new hole. Thank you very much!
Very helpful. Gonna keep these files till fans are never used again.
:O Bump for awesome.
This would have saved the life of my Raidmax case, had I gotten it earlier :).
Good find OP. This will save me hours and hours of calculation and eyeballing the positions. ^__^
Very useful.
But I think it is faster to draw a circle on a piece of paper with a compass ;)
Crap, the origional link is broken. I tried to go the the domain without the asp at the end and nadda.
I need to cut one 80mm fan hole and one 120mm fan hole. Does anyone know where I can find a template? Much thanks. :)
I have the original fan templates... all I need is somewhere to upload them. :cool:
I made a bunch of single fan and raditator templates in PDF form, and Bill O. has them available on his site here. Sizes range from 80mm - 140mm. Enjoy.
