Fan Switch
fezz
I am trying to make a switch for my 120mm fan. That's pretty much as far as I have gotten. Here's what I have so far:
From here do I just need to connect the stripped power wires to the switch and strip and black and red power wires from the fan and connect them to the switch as well?
All you have to do is inturrupt the circuit, so I would think all you need to do is hook up the black ground to the switch then back to the fan. Switch off, open circuit, no fan; switch on, closed circuit, fan on. Shouldn't need to hook up the other wires.
