fan speeds, need advice
xnikx
ok in bios this is what it says
i have a 680i mobo, does this look right?
Aux Fan Speed Ctrl, % [100]
nForce Fan Speed Ctrl, % [100]
Chassis Fan2 Speed Ctrl, % [100]
Chassis Fan Speed Control [SmartFan]
if temp > 60C, set fan speed 100%
if temp < 30C, set fan speed 1%
What is AUX and what is the nForce fan?
if temp > 60C, set fan speed 100&#37;
I noticed a significant temperature drop (idle and full load) by setting my CPU fan to
if temp > 50C, set fan speed 100%
if temp = 20C, set fan speed 30%
I don't want the fan idle just because the temp is near room temp and this profile gives a good overall cooling profile based on a few tests (Orthos). YMMV.
