- Aug 24, 2006
I resecently changed my case fans, however i forgot its positioning, what is the general concept to find out if the fan has been placed for intake or exhuast??
Are you asking about if you've correctly placed a fan as an intake/exhaust fan as opposed to if you know which way the air will flow when the fan is turned on?
I took it as the first part of the question so I'll say this:
Front panel fan - Intake
Rear case fan - Exhaust
Side panel fan - Intake
Top fan (if case has one) - Intake (mine came as an intake, but I'm not sure if it'd hurt to have as exhaust too)
If you're asking as to which direction fan will blow, they usually have arrows as Shadow said and if not, just turn it on and feel for it. Usually there's a sticker on the middle of the fan and that's the exhaust side.
Top fan shouldn't be intake. Heat rises and should be exhausted through the top.
Sometimes on the outside there are small arrows that indicate airflow. Otherwise just plug it in and try it before you install them.
