Well I'll be damned... this game runs like a CHARM on my machine.
qx6850 @ 3.33ghz
4gb RAM
dual 8800 ultras
Vista 64
I have it on 1920x1200 Ultra settings, with EVERYTHING on full blast, including the highest AA which is 8x and the highest AF, which is 15 (weird).
I was having issues because there is a checkbox for vsync in the options before you enter the game, and regardless of whether or not it was checked my fps was capped at 60. I forced it off from the nvcp and it lifted the cap so I assume it worked. I figured I would hold judgment until I steppd out of the vault, and I did. I had around 60 fps when I was looking out into the HUGE environment and I could see really far. I went to the first town which was pretty elaborate and my fps didn't really dip one bit. I imagine I will see dips into the 40s in bigger firefights but the good thing about this game is that you'll want to use VATS a good amount so it's not like I will be running around full speed with guns flaring, which would probably hurt fps.
Just wanted to give you guys an idea of how this runs, on a machine that is about a year old. Pretty beefy cards but any new nvidia card should run this thing no problem, especially an SLI setup.
edit: also, I just turned on the SLI load graph and while it was not 100% it was pretty much almost all the way full the whole time.
qx6850 @ 3.33ghz
4gb RAM
dual 8800 ultras
Vista 64
