fade question
jcll2002
I have the xfi xtrememusic and logitech z5300 and i was wondering how to fade so that the rear speakers are louder .i cant find it. All i can do is enable cmss.
Also, the rear speakers sound alot worse than the front ones. It sounds like they are hollow in a way. There is a sort of echo. I cant really explain it.
Keep them further away from you... the speakers sound like SHIT if you're close. (we have the same set up.)
You need to go into the THX console to adjust individual speaker loudness.
yeah... did you notice that the front ones sound actually better than the rear ones? I guess Ill mount them to the wall and then it will be better.
