WarMace
- Aug 25, 2004
This is probibly a quick and easy question but iv searched and searched and dont seem to find a answer.
I have been using the graphical client for a long time, and decided to try the console client.
I thought it would be diffrent, and i think i screwed up the settings. So my questions are below.
How do i remove/uninstall the client cleanly?
How do i modify the settings (or check them) after inishial instellation?
I have a Hyperthreading processor, and only 50% of it is being used. Do i have to run 2 clients? Or can i change a setting?
