Eyefinity, is it possible?
Pacwageo
Is it possible to configure 2 portrait oriented and 1 landscape oriented monitors in eyefinity? I'm currently using 1 3007WFP for my center monitor and I want to use the left and right monitors (2 2007FP) in portrait mode.
Any assistance would be appreciated.
Thanks
I'm almost positive it is not. Also, unless all the research I've done is from old software then you must run the same resolution on all monitors.
It's not supported. You can run those monitors off 1 card on the desktop, but not in games.
This really sucks because the setup that the OP intends to use would be perfect for Eyefinity.
