Eyefinity Help
tanin
Hey everyone i currently am using an I-inc 28" 1900x1200 http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4938558&CatId=3774
Now i probably can buy 2 more of these monitors but it probably would be cheaper if i bought 2 say 24" monitors and they rotate them to portrait and have them on either side is that a good idea or should i just fork out and buy 2 more 28inch's... Deskspace is not a factor but i know that the bezels on the 28's are pretty big.. so any suggestions would be greatly appreciated.
Eyefinity does not support Portrait-Landscape-Portrait setups. I also don't think they support having monitors of a different resolution although I am not sure on that.
is this not a portrait setup with eyefinity? so i have i have my 28inc in the the middle and then 1 24 inch monitor on either side in portrait ..
That is a portrait setup, that works fine. What you can't do is mix portrait and landscape in the same display group. The screen on the top in that setup is not in the same display group, it is extended, notice the 2.
Each monitor has to have the same resolution, so this doesn't work right now. You're not the only one waiting though, I have the Hanns G 28" and a 19".
Check out the video card - AMD flavor forum for much more eyefinity information.
