Hey guys, I'm having trouble finding the solution on AMD's website.
I am about to buy 3x Dell U2410s.
Right now I have 1 HD 6950 2Gb but am also going to buy a 2nd one.
However, I'm assuming I won't have to buy an active displayport adapter but I am not sure.
The AMD website says I need at least one display port and at least 2 of the following outputs: hdmi/vga/dvi.
But, since the Dell monitors have displayport and dvi I should be able to do the following for eyefinity correct?
Monitor 1: Displayport to Mini Displayport
Monitor 2: Displayport to Mini Displayport
Monitor 3: DVI to DVI
That makes sense to me, but the way AMD worded their setup guide with "at least 2 of the following outputs" made me think that I can only use one mini displayport.
Thanks for the help!
