Extra ramsink, where to stick them...
Stugots
i have some extra ramsink that came with my koolance waterblocks, and i dont know where to put them. its the system in my sig, ideally id like to put them someplace that would improve my overclock but i doubt thats going to happen. i have 8 of them i believe, any ideas?
You could put them on your videocard to get a better memory overclock.
Or you could place them on your MOSFETs. Up to you.
i allready have ramsinks on my video card ram, and i really didnt want to risk ripping a chip off by removing the existing ones.
Stick them on your Southbridge. Doesn't do any good, but it can't hurt anything. I had a passive HS that fit perfect on my southebridge, so I said what the hell? Stick it on there!
im a relatively new p4 overclocking, where exactly are the mosfets?
The little black things over the socket. You might need to cut up the sinks to fit it there.
CypHill said:
Put'em on your forehead. The chicks really dig that look.
Oh shit, so THATS what i've been doing wrong? i thought it was the fact im overweight, bad acne, and have no friends due to isolation!!!!
THANKS!
