burningrave101
- Sep 9, 2003
I have a new Lian Li V1000B and i'm thinking about buying a watercooling setup this summer. I would like something external so that the only thing inside the Lian Li would be the hoses running from through a rear PCI bracket.
Here is what i'm looking for:
http://www.guru3d.com/article/cases/200/9/
Are there any good external kits that you would suggest or is there any small external watercooling cases that i could install and internal wc'ing kit into and run it from that?
I dont know very much about watercooling yet but i thought i would start looking into it. I definitely know i want something external and small as possible though.
