External water cooling kits
well after just over a year having my antec 900, the noise of the fans is getting bit much. As im finding im overclocking more and more and the temps are gettin higher so the im having to turn up the fans. I really like the look the case as a whole so getting new case is a no no . So that why im looking at "External water cooling kits"
Are these kits any good in terms of price/prefomance?
if yes what kit would u recommend Zalman / Corsair etc?
cheers guys
woops wrong section. could admin move this to watercooling section please?
if you're looking for OC performance, its going to take more than a gimped external kit for *performance*, silent operation.
fake edit: you've got a duo at 3.2 and a 7900gs. I can't imagine you've got to turn your fans up *that* much. get an ultima 90 and a handful of yate loons and you should be good to go.
is just the amount of noise i want to reduce really. the fans r on med/low currenrtly but if i going to oc summore i would want the temps to stay low so that would mean turning up the fans speed.
