Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If you are using 4 High Speed devices, all transfering data at once, then you would take a performance hit. Basically you have 480 mbps that gets divided up. Chances are you are only using 1 or two ports at same time. Using = actively doing data transactions.
