What's the best way to secure an external hard drive so someone can't just unplug it from your computer and plug it into theirs and edit all of your files?
I was thinking just making a folder on the hard drive and then putting a password on it but then wouldn't that enable someone to just delete the entire folder (aka all of your stuff)?
Is there anyway I can just have the HD prompt you for a password?
Hard drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136247
Hard drive:
