XXX-OWNEDBYME-XXX
- Jul 9, 2004
quasimodem said:you can have like 254 of them hooked together right?
vbrtrmn said:I don't think so, there's only one port on that external drive, I'm not sure how you would hook them together. Or why you'd want to, for that matter.
How many power outlets do ye have in your room???quasimodem said:Tempting....
QM
QM
Apallohadas said:How many power outlets do ye have in your room???
Tiny said:With the correct amount of splitters/adapters and a little duck tape, you only need one.
Ahhh The mighty duct tape!Tiny said:With the correct amount of splitters/adapters and a little duck tape, you only need one.
Jozone said:Im in for one OP, thanks.
Just gotta check their reseller ratings prior to giving them my credit card.
