extension cable for this???
dep01
Is there an extension cable for this type of audio cable? if so, where might i get one? this plugs into my PC speaker's subwoofer..
thats not an audio cable. it problably carries power, audio, and control stuff. Your best bet would be make your own, or contact the manufacturer of those speakers.
You could, if you really want to dig, look up that connector on Digikey. I know that they sell lots of esoteric connectors, and you might be able to find that one. Of course, you'd have to buy those connectors, find some cabling [or make it] that has the same # of wires, and then email the manufacturer to find the pin-out for the cable.
It could probably be done, I don't know why the company wouldn't tell you the pin-out, I know that people have done this before, but it might be expensive and a real PITA.
