I have a setup that I'd like to grow, but I'm not sure what is the best way. Also, I posted this to Overclock.net, I hope that isn't bad. Just wanted to disclose that fact - different audience here.
Current Setup
I have 1 3TB internal Seagate drive (1TB platters - ST3000DM001) and 1 3TB external Seagate drive (same drive as the internal). I manually backup from the internal to external.
The data is video and images, but important media that would be very hard, if not impossible in some cases, to replace. I don't care too much about write speed. I do have some HD movies on here too, so the ability to play Blue Ray movies without pauses is nice.
Needs
Plan / Options
I have an old PC that is a bit power-hungry, but could be used as a NAS / RAID, if needed. The CPU takes about 95W, so it wouldn't be a cheap or green solution, but its free for use.
Picking the best long term option takes priority. Once that is decided, I'd like to minimize the costs there as much as possible.
Which option - or a new one - should I go with? Also, any HDD recommendations?
Current Setup
Needs
- At least 6TB storage
- Backup that isn't in the same PC as the main media. I already have offsite backup of the most important documents
- Uptime during the daytime
Plan / Options
- Buy another 3TB internal and external. Manually manage the media separation between the two 3TB drives
- RAID10, then 2 3TB HDDs for backup. Makes sense, but 18TB to store 6TB of data - is that the most efficient?
- Use the 3TBs as backups, make a new NAS / RAID out of smaller drives. Will this be a better long term solution?
