Quick detail of systems:
Server 1 - DC, DNS, DHCP, Company Files
Server 2 - Secondary DC, Exchange
Server 3- BES (when I get the Exchange working properly)
FIrewall - Freeguard 100
Okay so anyway I deployed Exchange 2003 SP1 and it was working internally, but I wanted to get the HTTPS working so I can connect at home without a VPN. I followed http://www.petri.co.il/configure_rpc_over_https_on_a_single_server.htm and I created a SSL Cert using the CA built into Server 03 R2.
So I went to test and on the LAN I can connect to the Exchange server fine. So I created another profile to test the HTTPS setup. I added the Exchange server went to More Settings and checked Connect to my Exchange mailbox using HTTP and then in the connection settings i have the https://servername.domainname and have it set to Basic Authentication. The outlook /rpcdiag it showing its connected over tcp/ip.
I have checked on Fast or Slow Networks connect using HTTP and it connects still via TCP/IP but under the Req/Fail table it has Fails.
Any suggestions?
Any suggestions?
