evga sli question
jros
is there any way i can run an evga7800gtx in sli with an evga7800gtx w/ACS3?
i belive so, nvidia has a new release of drivers out so that you dont have to have the EXACT same card anymore.only has to be same kind of card ex. 2x 7800gtx's
yes you can. just put them in sli and the drivers will set them both for the lower clock speed of both cards.
thanks! but 2 quick questions:
1) does this mean that i could use 2 different brands of card (ex. evga and bfg)
2) could i oc the normal card to the acs3 speed then have the drivers set both the cards there?
1 as long as its 2x7800gts or gtxs so yes
2 if the norm card will OC at the acs3 speed without probs then ur good to go
If the the slower one can run the AC3 speeds then take the bios off the AC3 card and flash it to the slower card, then you'll have two of the same card =D
