evga gtx 295.
FLYINGDOG
I have this card and was wondering if the back plate is worth getting.
you mean the ifx-14? if so this doesnt belong in the video card section...
also you could fit 3 fans on there, might wanna consider getting another one of those deltas.
The evga backplate that you can buy.I seen one for 12 dollars
and im wondering if it worth buying.
Ah, I see. It doesn't look like it would help much, but it's a drop in the bucket compared to the cost of a GTX295 already, so you might want to go for it anyway.
I remember someone on OCN did a test with and without the backplate and he found out that the backplate brought temps down 10c, you can try searching for it, I would but I'm on my phone right now.
