krazyklutzykorean
- May 3, 2007
I have an evga 680i sli board in my computer. It was working great until a few days ago, when I was moving. I took the computer apart for the move and put it back together at the end, but now the computer will not boot. When I start it up, the led display scrolls through some numbers and letters, and then gets stuck on the number 26 for a moment, also letting out a long beep while the display is on 26. Then it scrolls through some more numbers and eventually gets stuck on FF, which apparently is normal boot. However, nothing shows on the monitor. The post code 26 for 680i boards apparently means "Gen Init onboard clock generator and sensor". I am not really sure what this is. The same thing happens when I take out the video card. I have tried moving the ram to different slots and changing power connectors, but the same problem is still there. Does anyone have an idea how to fix this?
Specs:
Intel QX6700
evga 680i SLI
XFX 8800GTX
2GB Corsair Dominator (Dual Channel)
Sound Blaster X-Fi Elite Pro
Thank you for your help
Specs:
Intel QX6700
evga 680i SLI
XFX 8800GTX
