eVGA 680i death and replacement fail
aphexddb
My eVGA 680i has given up the ghost. It started powering off whenever I started a game and finally would not even post. After much googling I found an arcane guide to bring back the evga board from the dead with a 1d bios error. The guide restored the board to POST'ing and I was happy to have dodged a bullet. Too bad I got exited, after the exorcism I was only able to boot with only 2GB.
I tried swapping the memory around (2x dual channel Corsair 1GB sticks) from slots 3 & 4 to slots 1 & 2 but it refuses to post with anything in slots 1 & 2. All the sticks worked in slots 3 & 4. I believe the memory controller has crapped out or I have an evil RAM gremlin. I'm lazy and didn't run a memory check, shame on me.
Currently the PC won't run most apps except browsers. Windows does strange things, in short the system is hosed. While I am drooling over a quad-core i7 I can't swing the $600 for new motherboard, ram and CPU. The issue is I can't find anyone that sells a) the 680i motherboard or b) any 775 socket in its class. I envy the chaps that still have a working model. I found this thread but all of those boards are no longer available as well.
Any places where I might be able to replace my 680i? Maybe buy all new RAM from MicroCenter and see if thats it? (system specs in sig)
EDIT: I ran the windows memory diagnostic and the Corsair memory is 100%.
I would look for a used P45 off the forums here. Get you further then any nvidia chipset. I see no reason to get one now if you do not need SLI.
Had the same board and just parted with it. I believe this board was originally covered by eVGA's Lifetime Warranty so you may want to check on that before purchasing anything.
Those were some lousey boards with that chipset, did'nt matter what brand they were all hot runners and all doomed to fail prematurely...
i owned 1 for about 4 months but got rid of it after i realized what a pile of garbage they were..never bought another nvidia chipset board again...
Those boards are total trash. Their electrical design is among the worst I've ever seen. Though yours survived longer than any I had. All 13 of mine are dead as a door nail. Most of them were either returned to the manufacturers / retail stores. The rest I've used for motherboard skeet shooting.
Look for a used P45 or X48 chipset based board. You'll be glad to did. You will need new RAM for an X48 board though for sure. It doesn't come in DDR2 flavors.
I have that exact same motherboard that I am just about to retire once the 1155 boards are re-released, Id definitely be willing to sell it if you still want it when that happens. (Im hoping within the next week or so). Its got no problems, just wanting to upgrade ^^
Get the hell out of 680i while you can! I had like 3 of those damn boards fail on me, it's amazing you lasted this long on it ;) At least try to find a 780i or 790i at a bare minimum!
Those are only slightly better than the 680i SLI. I've got a dead 790i SLI board here and a 780i SLI as well. They are crap, plain and simple. Non-reference designs are slightly better, but they've still got BIOS issues and high rates of chipset failures. I believe the silicon of the chipsets themselves are trash. At a bare minimum they weren't QC'ed worth a damn.
I've gone through 680i/750i/780i/790i hell. They're all terrible. The 750i, less so, but only just. Stay away from them. I had... let's see, 4 680is (2 reference, 2 non-reference), 2 780is (1 reference, 1 non-reference), 1 790i Ultra (reference). All horrible boards. Of 7, 5 died, 2 were returned because they wouldn't OC worth a shit.
OP, you only have one card right? The only reason anyone should even glance at a 680i/780i/790i would be if they were running SLI and had a very expensive LGA775 chip / couldn't afford a socket upgrade. With a single card, P45 as others have said. P35 would be fine too.
I have a BFG 680i based mobo used for a custom build a couple years back that has been running a Q6600@ 3ghz since it was first built and it's still running. Course I kept voltages at stock except for the ones I could lower and retain stability. Also I replaced the cheap thermal crap on the chipset which dropped temps on that almost 10*C if I recall, coulda been lousy heatsink installation on the board but either way it prob helped the board live this long.
The customer recently upgraded to a new system we built them and traded in thier old system but this thing is still rock solid.
It's a combination of poor cooling (which you helped by replacing the putty crap they used) and really poor quality control. Some of them do survive, but it's a painfully small minority.
An update on my fruitless quest, thanks for the tips.
I contacted evga and opened a ticket seeing if I was under warranty (thanks JookyOne). They wanted me to check the cpu pin contact as well as take the mobo out and stick it on a board, presumably to make sure I had no shorts :| That went well:
Answered By Matthew H (02/21/2011 11:17:24 PM): Hello,
I do apologize the board is not working properly. If this is known good ram it would seem like a corrupt bios or possible problem with the memory controller. Unfortunately the board is currently out of warranty, we regrettably would not be able to offer you a replacement at this time.
thebaest, still selling that board? :)
I had an MSI 650i SLI-FI and it OCed like a beast and never blew up even after more than 3 years of use with my E6600 @ 3.0ghz stock cooler. But I would definately suggest finding an x38/48.
You can find the proven again and again GA-965P-DS3's for $40 shipped on the forums. No multi GPU support but they would boot stomp the 680i in OverClocking and overall stability.
Other than that you should be able to find an X48 mobo for between $70 and $100 tops on the forums.
