ethernet drivers on A8N
Is anybody else having some problems. Like the first ethernet connection, i left the nvidia ethernet driver on. And the 2nd one i installed the yukon/marvell gigabit drivers on. Well for the last couple of days, i been downloading umm...fairly big files off mirc, anyways, they would always get cut off somehow, and the speed would be up and down constantly. Well i plugged my ethernet cable into the gigabit ethernet connector, and i don't have those problems while i'm using that port, the speeds stay up, and my downloads don't get cut off. Is this a common problem? can i just install the gigabit driver on both connections?
thanks
Eric
No you can't use the Marvell driver for both ports.
I've used both of them on my A8N-SLI Deluxe. No problems with any file transfers on the LAN or with Internet downloads.
Maybe it's just karma for your downloading of 'large files from the irc' (warez anyone? ;) )
does anybody know what some of those options mean in the advanced tab of properties of the ethernet port. Like one of them is "optimize for" and then you choose either cpu or throughput. I'm wondering if i turn that to throughput if it will keep my speeds up
Probably not. If you're running at gigabit (as opposed to 100 or 10 mbit) speeds with high network load it will make a difference at the cost of higher CPU utilization. Otherwise you won't see any improvement.
right, well i'm not running at gigabit speeds or anything, i'm just running off my cable speeds of 3mbps downstream. But even on my old computer i could keep a steady 300kbps transfer rate, and i can now on this gigabit port, but on the other ethernet port i couldn't hold a steady rate, it would fluctuate up and down constantly.
Try forcing the 'Media Type' option to 100 half duplex and see if that makes a difference.
You can also try 100 Full Duplex if you're still having problems, or try setting the 'Maximum Frame Size' to 1500, but don't change more than one setting at a time. Change one thing, test, lather, rinse, repeat.
