ESXi whitebox build
maz1324
I want to build an ESXi whitebox and I am looking for assistance with picking out parts and also ensuring they are compatible with ESXi.
I will be using this machine as an ESXi whitebox. It will be used for myself for learning purposes, nothing will be on it that is production or requries 24/7 availability.
I would like to keep it under $1000, but I have some flexibility.
US Pittsburgh, PA. There aren't any Microcenters or Fry's nearby
Everything required for the physical machine. Case, PSU, motherboard, RAM, CPU, Hard drives, USB drive for OS
I was thinking a 240GB SSD, 1TB HDD or greater and 32GB ram. If those specs are too high for the budget, I would be willing to cut back on RAM and purchase more at a later date.
The case is the least of my concern. The machine not be out in the open.
None
6) Will you be overclocking?
No
N/A
Within the next week or two.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Compatibility with ESXi. Minimum of 4 SATA ports.
Yes
You could do a 8350 and a 990fx motherboard with 32gb ddr3 and It would have passthrough.(IOMMU)
Put an SSD in there(or 2+) and it would be pretty fast. You can add a single/dual/quad intel network adapter in it.
