Hey all. I've run into a bit of an odd problem with ESXi 4.0u1.
Background: I'm messing around with ESX/iSCSI in preparation for an MD3000i in house. I'm currently using OpenFiler, and a Win2k8R2 machine for various testing/proof of concept.
The solution works in a bare bones configuration currently. I set up a separate vSwitch - at first, not even tied to a physical adapter, addressed properly, and I was able to map LUNs on the Windows machine.
The problem is jumbo frames. It appears that ESX supports jumbo frames, albeit appearing to be unsupported officially. Most documents reference enabling jumbo frames on the vmkernel however. Right now, after issuing the command 'esxcfg-vswitch -m 9000 vSwitch2' (iSCSI vSwitch) the two will not utilize jumbo frames. The R2 box is configured to use jumbo frames on the 'iSCSI' interface, as is OpenFiler. A 9k frame ping fails to respond in either direction.
The twist: SSH'ed into the ESX box, it WILL ping the VMkernel port with a 9K frame.
I have since associated the iSCSI vSwitch with a physical adapter, thinking that may have been causing the problem. No dice. I feel like the ESX config is solid, as it will ping itself with the appropriate frame size.
Again, this is just proof of concept, I'm doing this more for my own benefit, as the real solution will have appropriate physical hardware. I'm more mystified as to why this isn't working at this point. Any comments/suggestions are appreciated.
