Hi,
ESXi 5.1 supports stateless/stateless caching(?)/stateful autodeploy, i.e. the host boots via PXE and gets its complete ESXi + configuration from a vCenter server.
Now, I only run 1 ESXi host but I do run an extra DHCP, DNS and NTP server on a http://pcengines.ch/alix2d3.htm using NetBSD.
Now my question is, can ESXi be autodeployed "manually"? I suppose it's all just PXE and TFTP, is it? Also, the files are not big. They could fit on the 4GB CF card in the ALIX just fine.
Ideally, my ESXi would boot via PXE and the config would safely be stored on the embedded server. Is this possible or does autodeploy involve complicated communication with vCenter?
I'm asking because my (internally attached) USB key somehow became unreadable in just 60 days of runtime. Since it vanished from ESXi and I couldn't get it to reattach properly, I suppose all configuration I did since then is lost. I'm in the process right now of upgrading to ESXi 5.1 so I don't know the real damage it took. It's even a SanDisk and it barfed.
PXE boot would be a nice way to get rid of yet another failure-prone component.
Update 2013-01-17: posted working(?) method.
