I asked about this over in the storage section and got nothing, hope to have better luck here.
The array is an Eonstor A16U-G2421 SCSI-SATA DAS system. I never expected stellar performace with this config but performance is unacceptable (to be polite). IOmeter results summarised below.
IOps: 6094.557039
Read IOps:3050.704829
Write IOps:3043.852211
MBps:23.806863
Read MBps:11.916816
Write MBps:11.890048
IOmeter tests performed from VM hosting the storage using lopoetve's "vmware-iometer-testconfig.icf"
1TB file copy (writing to array) across Gigabit network takes > 4 days. Yes days.
Configuration
Array Side
Server Side
I hope it's just a config error somewhere on my part, the array has performed well in the past but not in this setup.
Cheers
Simon
IOps: 6094.557039
MBps:23.806863
Read MBps:11.916816
Configuration
Array Side
- 12 x Hitachi Ultrastar A7K1000 HUA721010KLA330 SATA 3GHz 1TB disks.
- RAID 5 + Hot Spare, 128 KB stripe size.
- 5 x 1907218 MB partitions on the Logical Volume.
- Each partition = 1 LUN.
- Channel configuration at the link below. The problem appears to be that the "Current Transfer Clock = 40MHz" vs "Default Transfer Clock = 160 MHz". So the array is performing at only 25% capacity.
Server Side
- Server running ESXi 4.1.
- Intel SE7520BD2 Motherboard.
- Adaptec 39320A-R 64-bit 133 MHz PCI-X, dual-channel Ultra320 SCSI HBA.
- Using embedded VMware AACRAID driver.
- SCSI HBA Config as per Eonstor instructions:
○ Disabled "QAS" (function not supported by RAID controller).
○ Enabled "BIOS Multiple LUN Support".
○ Disabled "Domain Validation".
○ Disabled "Host RAID".
- 5 x 19.7218 MB LUNs = 5 x 1.82TB datastores.
- 8 MB block size.
- Buslogic Parallel SCSI Controller.
- Windows XP SP3 32 bit.
- 1 x 1.82 TB VMDK per datastore.
- All 5 VMDKs striped (RAID 0) under Windows.
- 4KB cluster size.
Cheers
Simon
