So for the past 3 years or so i've been using one 2TB and one 1TB external HD. I'm currently using a 150GB internal, main HD which Windows is installed on. Initially i connect my Externals to the computer VIA usb - soon after i realized that directly connecting eSATA plugs from my externals and SATA ends directly into my motherboard gave incrased transfer rates, so thats what i did.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822207017
Just recently i needed to purchase another 2TB external since i'm running out of space. The SATA wires would run through the rubber plugs/openings on the back of my case which are meant for plastic water cooling tubing - but seeing how i don't water cool, i've used them in this manner.
While browsing newegg for another external, i noticed eSATA brackets which allowed two ports, since i have three externals, i bought two brackets.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816068
and 3 wires to accompany,
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816035
My plan was to, instead of feeding the wires through the water cooling holes, i would just install these brackets and simply plug each external feed into each of the brackets ports (for each HD), while the brackets wires would connect into the SATA 02, 03, 04 etc.. ports.
Well, i hooked everything up correctly, and my OS is having trouble "seeing" the externals. When i plugged the HD's directly to the motherboard, (eSATA to SATA) the OS had no problem noticing them. But now that i'm running from the HD's, to the brackets, to the motherboard, windows is having trouble picking them up.
(i could go back to the old way, but this seems more 'clean' or efficient, rather than feeding the wires through those holes and unhooking the wire from the back of the actual external HD's whenever i go to clean my case etc..)
Any reason for this? If so, can you give an explanation? Appreciate the help.
