Now having another problem... got an error about 30% through a WU. THis has never happened before. This system has been rock solid stable for weeks. I am getting temps of about 55C on the CPU, but its been that hot for awhile, and I didn't think it was too high.. but maybe it is on a venice core 3000?
I am OC'd to 2500, but i have had it higher with no problems.
Sohuld I be concerned? Could it be a one time thing?
The next WU it downloaded, was running REAL slow.. amber core, that usually gets about 8 min a frame... its now running at 17....
Not sure what to do, except maybe turn down the OC....
I am going to WC.. parts starting arriving today... that may solve the issue.
thanks for any possible opinons!
Chris
Hres the Error
22:22:18] Completed 1500000 out of 5000000 steps (30)
[22:35:39] + Working...
[22:49:46] Quit 101 - Fatal error:
[22:49:46] Step 1544994, time 3089.99 (ps) LINCS WARNING
[22:49:46] relative constraint deviation after LINCS:
[22:49:46] max 0.000769 (between atoms 972 and 974) rms 0.000040
[22:49:46]
[22:49:46] Simulation instability has been encountered. The run has entered a
[22:49:46] state from which no further progress can be made.
[22:49:46] This may be the correct result of the simulation, however if you
[22:49:46] often see other project units terminating early like this
[22:49:46] too, you may wish to check the stability of your computer (issues
[22:49:46] such as high temperature, overclocking, etc.).
[22:49:46] Going to send back what have done.
Chris
Hres the Error
[22:49:46]
