It says this when I try to login:
Server Error in '/' Application.
s_root
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IndexOutOfRangeException: s_root
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[IndexOutOfRangeException: s_root]
System.Data.Common.FieldNameLookup.GetOrdinal(String fieldName) +55
System.Data.OleDb.OleDbDataReader.GetOrdinal(String name) +63
System.Data.OleDb.OleDbDataReader.get_Item(String name) +10
domaindlx.RedirectUser.load(IDataReader reader) +532
domaindlx.RedirectUser.lookupUser(String username) +379
domaindlx.RedirectUser.lookupUser(String username, String password) +9
ASP.Default_aspx.__Render__control1(HtmlTextWriter __output, Control parameterContainer) +286
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +27
System.Web.UI.Control.Render(HtmlTextWriter writer) +7
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +243
System.Web.UI.Page.ProcessRequestMain() +1929
Version Information: Microsoft .NET Framework Version:1.1.4322.573; ASP.NET Version:1.1.4322.573
s_root
Source Error:
or:
<configuration>
<system.web>
</system.web>
</configuration>
Stack Trace:
