Epox 8rda+ problems
bear187
aving a problem w/ random reboots. I have never had this problem before, but just recently the fan on my videocard gave out, thus overheating my videocard. I replaced the card after a while, and the problem started then. I have Windows XP Professional, just formatted to try to fix the problem and it didn't help. I also updated my bios to no avail.
What happens is when I boot up, I hear cracks in my headphones when Windows is loading, once it loads. It may reboot here, or it may not. It's about 50/50 chance. Once it loads, if I open up a video game, the crackling persists and is accompanied by some other odd sounds from my headphones, and then a random reboot.
I noticed that if I turned down my FSB clock speed to 133mhz rather than 166mhz this didn't happen, however I'd like to run at 166mhz so I can get full performance from my processor.
Also, I can keep it at 166mhz if I remove one of my sticks of RAM (I have 2 512mb PC3200 DDR). So right now I'm running at 166mhz with 512 RAM.
I don't understand why it's doing this, my only guess is that my power supply is shot and I need another one. The one I currently have is 350w, which should be plenty for what I have.
Also, when I boot up to my BIOS screen and it shows the voltage monitors, the vdd category dips down to as low as 1.28 at times. Should this be at a constant 1.5?
PS - I have a GeForce Ti4200 4xAGP 128mb, so it shouldn't be sucking up too much power. Nothing fancy inside either, 1 CD, 1 DVD, and 1 80GB HD.
edit: replace the psu to no avail. still does it, even at 512 166mhz now. What's the deal?
