Bubbleman82
- Aug 24, 2009
Hi all
I've been a long time reader but this is my first post. Not sure where to put it as its pretty general. Ive seen some pretty knowledgeable people on here so I decided to give posting my question a shot. So here it goes.
Basically I have some question about a proposed set up I have in mind. Here is a diagram:
Here are my questions:
1) Will the cable box->receiver->monitor work? From my understanding the TV tuner is in the cable box so the receiver will be fed SD cable, which the receiver will upconvert to 1080p. Are there any potential problems that will make this not work? will the picture be stretched/ squished in any way?
2) Another question that I have is related to switching between sources. I plan to use this as a second monitor for my Macbook Pro, and have the dock on the 2209WA. When switching away from the computer input on the receiver, will the external monitor still be registered as active is OSX, leaving the dock and all my windows on the external monitor? If so, how would I be able to fix this?
3) Any other problems that jump out at you about the proposed setup?
Sorry if this is hard to understand, its hard to articulate what I'm actually trying to ask.
Just want to make sure everything will work together before I pull the trigger on buying all this stuff.
Thanks in advance.
Thanks in advance.
