Enough rad?
computerpro3
LightningRod
Considering getting back into watercooling. I haven't had a WC'd rig since my old silver Cathar G5 days :p
Is a RX240 plus a RX120 enough to cool a 5.3ghz 2600K and 2 6950's flashed to 6970? This is pretty much the absolute maximum I can fit in my case.
RX360 or equivalent minimum.
Edit - Yes an RX240+120 should suffice, just make sure the heated water hits the 240 first then the 120.
umm, barely, but you may be able to pull it off. You won't see great temps though, you'll probably see CPU temps in line with what it would be with a good air cooler, and maybe slightly better GPU temps. You'll probably see your 6950's hitting ~65-70 C under load. I'm not sure what the i7 would hit.
For water cooling that much stuff you really should get a case with at least 1, if not 2 or 3 more spots for a 120/140rad.
