heatlesssun
Extremely [H]
- Nov 5, 2005
I think I just borked the motherboard in my sig rig, bummer. At any rate looking to build something using all the parts in my existing sig rig and replacing the memory, motherboard and CPU. Here's what I'm looking at:
MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
RAM: http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16820227424
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202&cm_re=i7_920-_-19-115-202-_-Product
What would be a good air cooler? I should be able to hit 4 GHz on air with a good cooler correct? Thoughts?
Thanks in advance!
Thanks in advance!
