Electron Microscope screenshots
frank b
Here's one of 3 of my boxes at work. My main machine is the one munching on the 600 pointer and the other 2 are set to the timeless units. I have a 4th one here but I've had some trouble getting it to show up on EM3. I think it's a sharing issue or the nut loose behind the keyboard.
I'll post my home shot when I get home. :)
can i have the points?...PM me for team and username please..i need the points
Yeah I like the mystery also. I'm so [H]ard that I don't want EMIII running because it will waste valuable cpu cycles. :) Nobody get me wrong, it doesn't really use many at all, but they are cycles. :p
MN Scout
For those who don't use some kind of monitor, think about the waste when something goes wrong and you don't know about it. :eek:
Here is the [H]ard|OCP Team Skin made by SKYY ---
I had a hard time to setting it up. Is there anyway I can use ip address from other computers to keep track of my folding?
I use \\192.168.xxx.xxx\whereyouputfoldingat
It complains, I just hit -ok-. Move the orginal two dialog boxes from the middle of the screen so you can get to the error message
edit: i think the folding dir needs to be shared
yes, the folding directory needs to be shared on the PC you're tracking.... That way you can find it, add it... and EMIII will know where it is from then on....
Keep on Folding!!
I walk past all of my borg's once a day.....so I guess I am the monitor.......and teh ones I don't walk past are running timeless wu's on machines that get shut off and on so much it is like watching a yo-yo.
Dunno if this is what you were trying to get people to do, but here's mine:
Had to separate it into two images.
LPerry, any chance on adding a "(23) Client View"? :D
Oldbenwa
One of these days...
That's probably the #1 request... more viewing area. ;)
I like the size and info provided on the "(3) client" config..... but I do wish that I had more than 4 boxen to monitor in more than one place.... 2 here at work, and 4 at home (counting the 2 instances on the P4)....
What are the limiting factors to have it set at 13 boxen? (Just curious)
Keep on Folding!!
I'm the same way. Even at home where I only have 2 running (for now ;) ) I prefer the 3-client view.
I just need to see how many points and how long til it's done. So "(13) Client View" works fine for me.
Oldbenwa
You can set the "13" view if you're running 1, or 100... doesn't matter...
It's all just a trade off of how much info you can get on there at once. ;)
I'm mostly interested in seeing if anything is wrong... I know that at a glance. ;)
