I'm working on a design involving an electromagnet which receives its power from a capacitor, meaning that the electromagnet is only powered in pulses (when the capacitor discharges).
Since the current going through the coil of the electromagnet is limited only by the resistance of the coil, I need to know the maximum frequency at which the capacitor can discharge in order to keep the coil and surrounding structures from melting (or worse).
I realize that the produced heat and the rate at which this heat is removed depends on the design of the coil and the environment, but all I need are some references to sites or other with information which will allow me to calculate the maximum frequency.
From a site on railguns or similar I got the figure of maximum 0.5 Watt/square inch as a reasonable treshold for the heat buildup inside the coils. How realistic is this?
Also, what is the typical time a capacitor requires to fully charge itself?
Any help, tips or requests for more information are welcome
