I need help with a few question, please don't chew me out for getting a dell it's a decent pc and I got a good price on it. Should I reformat the pc first now or just keep the install that dell put on the drive? If I do format I assume every app installed in located on the dell cds I have so I should loose nothing right? Lastly as far as I know this is a 925x intel board with integrated audio,under sound devices it says
Analog Devices ADI 198x Integrated Audio but isn't that the old standard 5.1 audio and NOT the new intel HD 7.1 sound?
Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Also I plan on upgrading all the drivers but I'm not sure what is the best way to handle this and could use some advice. Should I uninstall the old drivers before I install the new ones? And with the dell mobo can I just use generic intel 925x drivers for the chipset or do I need dell drivers? Or maybe it's best to stick with the old saying if it aint broke don't fix it and leave everything the way it is unless there is a problem and THEN try new drivers?
Thanks
