Hardware
E8400 - stock speed
Gigabyte P35-DS3L
Cooling
Thermalright 120 Ultra Extreme w/ Scyte S-Flex 1200rpm
Exhaust - 1x Antec Tricool on Low
Intake - 1x Antec Tricool on Low
Bottom chamber - 1x Antec Tricool on Low
So these are the readings I'm getting. These are idle temps. I'm thinking maybe these could be better. Yes, the TRUE is bolted down as securely as I could get it. The thing is, the stock intel fan performed only 2-3 degrees idle worse than the TRUE in my system.
Under full load, I get about 10c increase over idle.
What do you guys think? Okay?
and yeah, HWMonitor on the left displays the temp with TjMax of 105 whereas Real Temp on the right uses 95c
