E6750 users...
Konceptz804
How much voltage are you guys giving your chips to reach 3.6ghz+ clock speeds?
I'm currently at 1.51v @ 3.65volts and my concern is that with this being a GO stepping chip i'm giving it too much voltages as I've read reviews and seen other users at 3.6ghz on stock vcore. Now I've tried lowering the voltage in windows with the nvidia control panel while running prime and that's the lowest voltage I'm stable at.
Also that voltage is what Everest and cpu-z are telling me, I understand the bios settings are wrong as i have it set in bios at 1.565 something. I'll post screens when i get home as I'm at work now.
I understand every chip is different but I wanted to get a bases of what voltage everybody else is running to achieve similar speeds.
E6750 GO
EVGA 680 SLI A1 Board with latest bios
I am at 3.3 ghz at stock voltage of 1.344. At least that is what CPU-z tells me.
mine needs about 1.36 volts to be orthos stable in 3.6ghz, week/batch code 3738b104
also - set voltages from bios, dont mess with them within windows.
