e6600 multi
There seems to be a problem with my board not displaing the right multi. Cpu-z shows it correctly but easytune or orthos dont show the correct speeds. for example im using 400x8 =3200mhz. Cpu-z and orthos would show 400x9=3600 even with multi in bios at 8. Im using the f3 bios in my ds4
more likely a detection error with those programs,you got the latest versions
